quick QuEstion =)
krbZX6590
Car: 1990 nissan 300zx
tell me what's wrong....it takes a lot of effort getting into gear especially when cold and it grinds if I don't push or pull the stick shift hard enough into gear. I'm thinkin I neeed a new clutch but I have no idea its my first car
Hybridpunk420
Car: 1993 nissan 300zx NA
i had the same problem... new clutch fixed it...
freakonaleash1187
Car: '93 300ZX N/A, '97 200SX SE
Or try changing the transmission fluid. A lot of Z owners use Redline MT-90 Transmission Fluid, just for a suggestion.
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
is there excessive play in the shifter? the bushings and even the shifter support bracket are typical problems that can prevent the gears fully engaging
DustinZ
Car: 1990 Z32, rb25 s13, 1980 S130 10th anniversary, 1978 5speed fact ac s30, s2 rb26 on deck!
Could be a number of problems. I would think a hydrolic issue. Try bleeding out the clutch system real good. Also check to see if the slave is leaking at all. Lastly I would also think maybe it could be a bad pilot bearing as this would catch the input shaft and cause it to spin even when the clutch is depressed.
DustinZ
krbZX6590
alright new symptom...it fixed itself for a while and wass shiftin like butta but now its actin up again its sooooo annoying....I have no idea what's wrong
evildky
06 Nissan 350Z GT
does the shifter feel sloppy ?
Ill give u a head start
Car: 1993 Nissan 300zx Twin Turbo
i had a very similar problem on one of my first Z32s. I came to find that it was my clutch master cylinder. If u double pump it will it go in gear?
krbZX6590
what do you mean does my shifter feel sloppy??? ...and double pumping the clutch doesn't help but when I get into first my rpms drop when at a dead stop
phanatikz32
Car: 1991 NA to TT z32 biatch!
krbZX6590 wrote:what do you mean does my shifter feel sloppy???
is it excessively loose?
does it grind into gears when driving? it could be sychro's?
evildky
06 Nissan 350Z GT
does the shifter feel precice or does it seem to have a lot of excess movement?
