themadscientist »
https://forums.nicoclub.com/themadscientist-u2806.html
Tue Aug 15, 2006 2:11 pm
I assume the maps in question were set with the system set up to blow through the MAF. With you now drawing through it you will need to redo them. The MAF measures air by keeping the wire heated to a set temperature and the voltage required to do that is the system of measurement. Air under boost, hot and screaming past the wire at 20PSI does not behave the same way that cooler, denser ambient air being sucked into the MAF would. The computer attributes each step of voltage as a certain amount of air and fuels accordingly, it has no way of knowing that the voltage in question now equals a different volume of air so it is not fueling correctly. Luckily you have a map that is in the ballpark to start from because you will have to build a new one for this new arrangement.
