Quick question
Okay
I searched and read somewhere that boost_boy said that stock main studs are tough enough. I was just making sure before I should order ARP SR's main studs. Thanks guys
pulsar gtr
Car: NISSAN VEHICLES
Yes, the stock studs are pretty dam good. I believe that the studs that nissan uses on their engines are rated pretty high compared to other engines from different manufacturing.
What setup are you planing to go with , turbo? how much boost? etc..
RafiPULSAR GTR
c-rad
Car: 1991 Nissan 240SX w/CA18DET
Okay wrote:I searched and read somewhere that boost_boy said that stock main studs are tough enough. I was just making sure before I should order ARP SR's main studs. Thanks guys
You talking about head studs, or main studs? CA uses main BOLTS stock and head BOLTS stock. SR main studs cannot replace the CA main bolts, but they can be used for CA head studs.
Okay
Thanks guys. Im not running anything high anytime soon so it's ok.
