Joeygsxr »
https://forums.nicoclub.com/joeygsxr-u35702.html
Wed Jan 11, 2006 10:05 pm
im installing a gt28 on my ka, im planning out all the lines, ordered the atp restrictor inverted flare to an fitting for the oil supply, i know the size of the water lines fitting m14x1.5, but im debating what an size to go with -6an or -8an is the diameterof the hose and fitting all that important on the water ines? i know it is with the oil return. every one says min. of -10 and the oil supply can be -4 with the restrictor, but what about water lines? and if anyone wants i'll have all the part numbers for the lines when i order everything , i'll do a write up, to keep cost down you can always use jegs brand lines and hose ends, and earls an adapters are decently priced ,
