thanks very much that answers the question...the reason i asked is cuz some shop said i needed to do different wireing for the ABS, just needed clarificationtenkawa_akito wrote:The ABS is wired in differently from the EFI setup. The only problem the ABS will give you is that it'll be in your way when you're working with the wiring harness to get it in/out of the car.
