quick question
SHIFT_240sx
Car: 91 Nissan 240sx SE Coupe
will the ca18 engine work with the ka transmission?
Structure240sx
not directly and probably not at all
some say and have done sr and rb trannies with the ka bellhousing on a ka and vise versa. internally the same jsut bell housings can be swapped to make it work
not sure about the ca
masticatingcow
Car: 94 Mazda FD3S
Why not? All the S-chassis MT gearboxes were the same.
Still, you'd run into the issue of finding a CA18DET bellhousing. I suppose if you're REPLACING your transmission, then you'll be fine, but if you don't have a CA bellhousing, you probably should just find a CA transmission.
