Quick Question (removing intake mani)
exode
Car: 90' 240 w/ 400hp SR20DET
I've got all the mount bolts, block bolts, hoses, and other crap disconnected. Its still on there pretty firm, even use engine diagram to make sure I wasn't missing anything. This is an old engine, you think that gasket is that strong?
Break the gasket? Laservision?
Thanks =)
sr20det redtop
9240sx
Car: What i believe to be the cleanest s13 in the world.
SR20DET + RS*R-Apexi-Nismo-Trust-HKS= 100% pure love
Did you try tapping it with a hammer??
exode
Yes, do I need a bigger hammer?
Hijacker
Car: '92 240sx Convertible
'94 F-150
it's aluminum on aluminum. aluminum has this obnoxious tendency to fuse itself to things when it's been heated up. Just keep trying to knock it off with a hammer. More than likely, the bolt holes for the studs have just gotten too cozy with the studs. A few good taps should loosen it. You may also want to try a pry bar too. Just be careful not to break or bend anything.
da40
Car: 1995 SE 240sx
i second the pry bar idea thats the ive done it before
