They're probably used where the outer tie rod connects to the hub/spindle, they're to keep the rod parallel with the ground. You only need them if your car is lowered. That's the way my SPL ones are anyways, just add/remove until they sit level with the ground.asoomal wrote:There's nothing in the description about any washers for more steering angle.
Then your ball joints must not be seated properly. That is not where they go.SILVIAJayS wrote:
