I sprayed pb blaster on all the nuts and will let it sit over night.
My question what did you guys use to remove those bolts
I already tried a 13 mm open wrench but nope does not budge at all. (plus that stupid metal tab that is in the way doesnt help either, do we even need that when i install new turbos?)
So im asking do i need to use like a crows foot to take these suckers out or something else (sorry for the noob question just bumped into a minor roadblock
(I know this might be considered technical if its moved i would understand)
As you can see sprayed pb blaster on the studs to see if it helps
New turbos waiting to be installed
