quick question on tires
skylinedreams
Car: 90 240sx
I have a 95 base model and I'm getting wheels that are 17 x 9 +20I was wondering will a 255 40 17 fit with minor fender rolling. or should I go with smaller tires.
240sxjeff
Car: nissan 240sx zenki version
you might have to pull the fronts a bit, i have 235-40 9"+10 with rolled fenders and they still rubbed it was fixed with some camber though.So they can fit with a roll and some neg. camber up front but I would go with a 235-40 up frontIn the rear you should be perfectly fine with a roll.Camber is going to be your main issue on wether your going to rub or not.
skylinedreams
Car: 90 240sx
isnt a 235 gonna be stretch on a 9" rim though?
240sxjeff
235 is a stretch but not that much I can take some pics of mine and email them to you if you want, just give me your email addy
EazyBreazy
im going 235/45/17 on my 9's i'm assuming the stretch will look even less because of the slightly taller side wall
skylinedreams
Car: 90 240sx
hey 240sxjeff my email is [email protected]
240sxjeff
Hmmm. I would reconsider the 235-45 it doesnt really look right because the sidewall is just too tall, but that just my opinion.
Skyline You should have the pics in about 10-15 min, I have to find my USB cable
skylinedreams
Car: 90 240sx
hey man thanks for the pic I think i may actually be able to run 245 40 17's in the front cuz Im doing my s15 front end as soon as my hood comes and the fenders seem to be widebody. they def have a lil flare to them.
240sxjeff
No problem. Yeah most of those gay conversions come with wider fenders. Just check to see how much wider they actually are, because if they are like 30mm wider than stock, your wheels are going to look sunk in.
Bosrudorfer
Car: S14
skylinedreams wrote:I have a 95 base model and I'm getting wheels that are 17 x 9 +20I was wondering will a 255 40 17 fit with minor fender rolling. or should I go with smaller tires.
let me guess the 5zigen fn's right? I have them and run 235/45/17 (I would go with 245/45/17 if I could do it again)
here is a pic before the coilovers. I have no fender roll (but will sooner or later) and now run KTS coilovers and they fit with tons of space.
