Quick question on greddy profec 2 install
JonathanPrem
Car: 02 Nissan pathfinder 4WD SE
Hey,
Got quick question on greddy profec 2 intallation. Manual says i need to run one line of actuator and another line off the turbo. But only problem is my gt2871r doesnt have nipple. Do i have to weld on little nipple to the ic pipeing on the hotside?
xweav32
Car: 2011 Nissan Versa S 6spd (daily)
1995 Nissan 240SX SR20DET 5spd (fun car)
you can tee off any of the nipples under the throttle body or tee off the FPR. make sure you take all the caps out of the selenoid. it should go com port to wastegate: no port to boost source ie ^
badbob2121
Car: '92 Nissan 240SXS13 Hatch ELLIS JUAN
'12 Ford Mustang GT RTR
You need to have 1 hose running from the Greddy solenoid to the wastegate actuator and the other from the Greddy solenoid to a boost source (hot pipe). Just find a nipple fitting and drill/tap in a hole in the hot pipe, screw in fitting, connect hose. done and done...
Its easy
