Quick Question: Oil Pressure & Oil Temperature
chickentendah
Car: SR20DET Hatch
What are the typical ranges for oil pressure (in psi) and oil temperature (in fahrenheit) for a stock redtop? And after a pretty hard and boosty run, how hot can the oil temperature get on average?
Thanks
(need this info so I can buy the appropriately scaled gauges)
Def
Car: Cars, Engineering Stuffs
I just installed my Defi Link gauges, so no idea if my setup is right on but I've gotten this so far -
Peak readings
Press: 90psi at WOT warmed upTemp: 190*F on hot day and LOTS of WOT(a few minutes of fairly steady boosting)
Average
Press: ~10-15psi at hot idle, 30-50psi in the midrange, 40-60psi at cold idleTemp: Takes about 4-5 minutes of driving to really pull the oil temp above 120*F. After about 10 minutes it normally sits at ~150-160*F with moderate to hard street driving.
I have a GReddy oil pan, and the temps are taken in the pan. Pressure is taken before the oil filter next to the stock pressure sender.
Phax
Car: Control dynamics
Def wrote:Average
:withstup
Those are about the numbers that I'm getting. A good rule of thumb for oil pressure is that you want about 10 psi for every 1000 RPMs that the engine is spinning.
