Quick question. NEED an answer quick please
eliterit
Car: pignose
im doing the ka24e to ka24de swap right now and the high press ps hose i got looks like this. the only thing is with this connection with two female fittings at the end i can only find one male fitting in the engine bay to plug in. Is this the wrong hose?
I got the DOHC hard lines that connect to the crossmember and rack. Should i have not put those on and left the old sohc lines?THANKS
Dattebayo
click on this link... i think this is what the stock part looks like from a DOHC...
http://www.nissaninfiniticlub....d.jpg
As you can see, the design is similar, although your part looks like an aftermarket make.I think that the port parallel to the large hose is for an electronic sensor or switch.
