JRL »
https://forums.nicoclub.com/jrl-u26048.html
Thu Apr 21, 2005 9:15 am
Your MAF operates on a 64 bit (x axis only) grid. As more air passes by it, your ECU will read farther down the grid and then translate the given value into a voltage reading.
I just compared the 2 VQ maps (Maf maps) (DE vs E).
The first few points on the grid the E MAF has nearly double the value as the DE maf.... This is at idle, and it reads the same value for the 1st 12 points....so sitting still the E MAF may not be so good for your gas mileage.
But, from then on, the DE MAF reads nearly double the value of the E MAF up to about point 25 on the MAP....So, there is a chance that you will run a little lean from point 12 up to 25 or so.
From then on, they read very similar values (with in 100 points of each other, seeing as how they can read up to 60,000 points). Although it looks like the E MAF reaches it's max a few points earlier than the DE.
They look confusing, but, when there put in a straight line (like an X axis) they make a little more sense, and, you can see kind of whats going on.
Heres the KA24DE VQ MAP: 7,25,51,86,129,178,235,298,368,446,542,646,773,922,1120,1350,1535,1766,2052,2331,2635,2978,3355,3753,4173,4620,5100,5619,6171,6772,7433,8145,8899,9696,10553,11468,12454,13477,14556,15710,16958,18240,19583,20988,22481,24046,25693,27398,29157,31081,33088,35147,37214,39361,41589,43899,46294,48774,51341,53997,56742,59579,62510,65535
Heres the KA24E VQ MAP:320,320,320,320,320,320,320,320,320,320,320,320,370,450,560,700,880,1090,1350,1640,1970,2340,2760,3220,3720,4270,4860,5490,6180,6910,7680,8510,9380,10300,11280,12300,13370,14500,15690,16930,18230,19590,21030,22530,24100,25760,27510,29340,31280,33330,35500,37800,40240,42840,45620,48580,51740,55140,58770,62690,65535,65535,65535,65535
