Quick question in regards to the S14 fuel tank.
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
My question is as follows, how much does the S14 fuel tank weight when full? Help would be greatly appreciated, thanks in advance.
Dire91
Car: 1997 Nissan 240sx SE
I know the amount of gas in a full tank weights just under 100lbs, I do not know how much the actual gas tank weighs though. Hope that helps!
Jagstang
Dire91 wrote:I know the amount of gas in a full tank weights just under 100lbs, I do not know how much the actual gas tank weighs though. Hope that helps!
Alright thanks, that's good enough! Damn, but that's kinda heavy. . . That means my S14 weighs 2835 with a full tank of gas, and with the spare tire in the back.
I was just curious because my S14 weighed 2760 lbs on the scale, and it had a little over a 1/4 gas in the tank. . . So add 75 lbs more to that weight, and you get 2835 lbs.
