capowered240 »
https://forums.nicoclub.com/capowered240-u27587.html
Tue Jun 12, 2007 2:25 pm
What mode 5 is when the car is running or your driving it, when the ecu detects that a sensor is bad, then it will throw a trouble code. Just like when a sensor goes bad in any car/truck, the check engine light will flash. So if you have a fsm, look to see what trouble code 10/11 is. Right next to it will be what it should be wrong or bad. someone correct me if I'm wrong. hope this helps.
