Quick question for anyone that is knoladgable, and knows their s13's
redsx13
Car: 93 240sx 03 350z
Hi , I am currently building up my 93 240 and i ran across a couple of questions that i know the guys at nico could answer. There is an ecu under the center divider, but i cant figure out what it is. i assume it has somthing to do with the inside of the car but i would like to know what exactly does it control and can the car be run w/o it(i did search, but w/o the name of the component its kinda useless).
thanks
adrianfromthecastle
Car: 1992 Nissan 240sx
center divider?
The ECU is located in the kick panel of the passenger seat.
onosqv
Car: '92 240sx Vert
I'm pretty sure that's the automatic seat belts - to verify, you can unplug it and open/close your door. Your car can run w/o it.
redsx13
adrians_s13 wrote:center divider?
I know, there is another one under the center divider. its not as important as the one located at the passanger kick plate but is an ecu of some sort.
redsx13
i removed my autobelts which would make it hard to check. i hope it's for the belts, that way i can take it out as well. but i think it controls more than the belts, theres alot of wires coming out of it.
krazydriver
Car: 2002 civic ex, 1993 KA-T 240sx - parting it out...
nope, that box is just the belts.I've got mine laying on my floor behind me as i type this.
btw, if you download the FSM, it's in the diagram for the body harness connectors, is marked as solely a seatbelt controller, and shows the full pinouts for it.
redsx13
thankyou! one more thing i dont need!
