RedRum240 wrote: all I see is by the brake master cylinder a cylindrical thing with fluid in it which remotley resembles transmission fluid.
that smaller cylindrical thing is your hydraulic clutch fluid (brake fluid DOT 3/4)
soo, there's no dipstick on the manual trans; you'll haveta jack up the whole car evenly (to make it "level") to accurately check the level.
umm, 17mm open end wrench to the square plug on the driver side of the transmission. open it up & if the GL4 gear oil should be level/ some will come out...
heck, if i'm under there, i might as well change the gear oil since i'm already under the thing... (about 2.2quarts is needed) PS: most don't carry GL4 gear oil @ my local pepboys & i end up getting penzoil synchromesh 1 time in a pinch... from autoz0ne
might as well check the slave cyl on the pass side for any brake fluid leaks (peel back the dust boot)
Modified by ricebike at 5:15 PM 10/30/2004
