Quick question about the Greddy kit
240sxHitman
Car: Boosted '91 240sx
I was just looking at the greddy kit on Enjukuracing.com and is says
"This Kit is Designed for OBDII. If own a 1995 this kit will bolt on but if does not have OBDII you will need to purchase the Greddy Profec E-O1 or Support tool to reprogram the E-manage system."
ok now my question even tho this is for a 95-98 240 could it be put on a 91 and work properly with reprograming E manage system and of course new IC piping?
Red-KAT
Car: 1995 240sx-se ka24det
Its already been done if you do a search.
And the tune blows @$$. So yer guna have to do that anyways.
Ohh and the kit does not come with an FMIC. thats an extra $800
240sxHitman
Red-KAT wrote:Its already been done if you do a search.
i remember a guy saying he did it but some people were asking was there alot of modifications and stuff like that and i dont remember responding. yea i just remembered that the kit is without a IC but i just wanted to make sure.
240sxHitman
anyone know what the Greddy kit has for the oil return?? do you have to weld a bung on the oil pan as you have to do with the BD kit?
turbo98_240sx
Car: computers, cars, anything that can do something and be made to do it faster stronger or better
YES, the Greedy kit contains a steel? u bend tube thing that has an attachment on it that lines up w/ a screw hole on the oil pan (one that fastens it to the bock) and from that you can line it out on the pan and mark where you should cut the hole, anywhere that welds would prob only charge a few bux to weld it on. The hardest part was getting the oil pan off the car IMO. I'll see if I can find a pic of it some where installed or not.
get_up_mark
Car: 98 240sx se
how about swapping to the obd2 harness, ecu, and maf. but if the greddy tune isnt that good than dont bother.
Structure240sx
you dont need to swap any of that.
OBDII is only emissions related has nothing to do with anything else. it can be removed from a stock car and the car will run exactly the same only with a CEL
get_up_mark
Car: 98 240sx se
does the greddy kit come with an ecu tune or is it preprogrammed to the piggyback?
turbo98_240sx
preprogrammed in e-manage but as stated above the tune is crap
Red-KAT
Also dont remove the CAT from the car... The wastegate cant handle the loss of backpressure and will cause bad bad boost creap.
