quick question about rb20 wiring
driftmyke
Car: 1993 vert and a crazy fast 98 interceptor
ok so i have all my nessicary wires hooked up on the plug under my dash near the ecu except for the clock power.
the problem is the ka has the power for the clock on the cluster run from the plug near the ecu (same plug as tach, tempature gauge etc) and the rb doesnt. so my question is what should i hook the wire for the clock up to to make it work?
also if im gonna hardwire it do i hardwire it to the battery for constant power or to a wire only powered when the cars key is turned to acc.?
any help is aprecciated, im sitting in my garage tryinfg to finish the wireing right now so i need some quick help, thanks
driftmyke
bump
Vkoslak
Car: 1992 240SX SE rb26dett, 2004 Subaru Forester
Are you talking about the wires for the consult port?
driftmyke
no im talking about the plug right in front of the ecu on the passenger kick panel.
driftmyke
bump
im trying to find what wire from the rb plugs near the ecu to connect to the GREEN WIRE W/WHITE STRIPE on my ka plug near the ecu.
Vkoslak
Connector F1 is the FSM? That ends up at the consult connector that comes out the fuse box.If you don't plan on using consult, don't worry about it. I wired mine, I can look tomorrow sometime if you still want to splice it.
There used to be a doc on rb25det.org that was helpful to me, but I see that website doesn't exist anymore. If I get time, I'll write up a new doc detailing that plug for rb20det.
Vkoslak
I found the document I was talking about. I had it saved on my laptop.
I put it up here: http://www.vkoslak.net/~rjames...s.pdf
It's for putting a rb20det into an s14, however, it does have pretty good descriptions of the plugs and the pinouts with the color of the wires. You should be able to use the other wiring docs available and the foldout from the FSM to figgure out what goes where.
If you're still having trouble, let me know and I'll go look for my notes I made when I wired it up.
driftmyke
well my clock works so now the only thing that doest work is my heater blower motor.
one of the wires on the item i just downloaded of yours says O2 sensor/heater power on plug P, but i dont know what plug its on cause its hard to understand.
so yea i just need to know what to hook up to make my heater work, cause the is the only thing that isnt working now.
Vkoslak
Your heater doesn't work? That should work as long as the heater hoses are connected properly.
I don't recall doing anything special for the heater hoses.
driftmyke
so the heater has nothing to do with wiring?
**** i have the heater lines hooked up and nothing blows.
oh well the good news is that means i did all my wiring perfect cause everything works. haha pay somebody to do my wiring hell no.
Acecool
Car: 1989 Nissan 240SX Hatch Pig KA24E 126k
Bleed your lines properly, that is what I didnt do on mine :-)
On one of the hoses there is a little metal piece sticking out with a cap, open the radiator cap and that hose with the car started, and be prepared to put it back on - like only crack it off a little to let air out!
Josh
driftmyke
your talking about the metal connector that came with the rb? with the plug coming from it? k ill try that
oh just so i make sure i have the lines hooked up what line do you have that hooked up to on the firewall? upper or lower?
