Quick question about installing Stainless Steel Turbo Lines
soka
Just to make sure, does this correctly show where the ends of the lines go?
Also does anyone have any additional tips for the installation?
thanks!
Stephen
otterman
you got them backwards
240sxvaj
Car: 1991 240sx fastback KA-T- SOLD!
1994 MKIV TT-Daily/Track
use teflon tape on the threads before installing
CMG
Car: 1989 240sx Hatch w/ Redtop
This may be a dumb question, but what do you do about the water line that goes from the inner side of the turbo, to behind the egnine? I just pulled my set up yesterday, and I don't see where that ss line would screw in.
preludervtec
Not sure where the OP got his SS lines from but usually the coolant return line that goes behind the engine uses a hose clamp to connect to the metal line behind the engine. Look for pics of taka or circuit sport lines.
garagelu
Car: 1995 240sx w/ sr
preludervtec wrote:Not sure where the OP got his SS lines from but usually the coolant return line that goes behind the engine uses a hose clamp to connect to the metal line behind the engine. Look for pics of taka or circuit sport lines.
No you are wrong. On the s13 turbo lines one of the coolant lines has a clamp style end that goes behind the engine.
On the s14 lines there is a place to hook up the line on the coolant neck. That one screws in. And in the picture you do have them backwards. The 90 degree fittings go to the turbo and then the banjo and the straight fittings go to the engine.
You never told us what engine this is going on so I am assuming it is s14 engine looking at the turbo lines.
CMG
Ok, that might explain my confusion. I have s13, so I guess those lines are different than the ones in the pic.
soka
Hey
Thanks alot for all of the posts. Whew good thing i asked. >_< This is going on a notch top sr20 motor with the t28 turbo. So yeah its for the s14.
http://www.frsport.com/Circuit....html
Thanks again
Stephen
Modified by soka at 11:43 PM 12/3/2007
redtop91
Car: ↑ ↑ ↓ ↓ ← → ← → B A Start
Not trying to flame or anything, but was this thread really necessary? I mean even if you had it backwards, when trying to install them you would have figured out which way they went. At least I hope you would've.
otterman
Yes it was ****in necessary you idiot
redtop91
otterman wrote:
Ok. Just checking.
soka
Hey Otterman thanks for the help.. really i just want to get this done right the first time and i have no idea what im doing. its too bad these didnt come with any sort of instructions for the mechanically challenged..heh uh i got another stupid question... if you got a sec>_<
So i started putting these on and this one doesnt seem to fit well. is this correct or should the end of the 90 degree bend be rotated around the other way? if so then its hitting the cross arm thing.
Ignorantly to me it seems like the straight end is more appropriate for this location. Can that work??
thanks for helping me figure this out!
Stephen
garagelu
it would work better if you put the 90 on the turbo and turn it so it points down instead of up. Then route the line under the turbo and to wherever it goes.
soka
Thanks for the reply.
when i rotate the 90 bend down it then hits and lifts the cross arm so it cant connect with the tab thing.. Is there a reason you cant put the straight end on the turbo? This is for an s14 motor and t28 turbo.
thanks
Stephen
stacy
Car: 1990 nissian 240sx se
hey did i figure out which way ur turbo lines go ?? cause I kinda need some help with it too ? you have a pic of ur final outcome?
CMG
Damn, it took me like 5 minutes to scroll all over the pic until I could see it was Vader. I think I'll print it out so I can have a life sized vader poster on the ceiling in my room....
duffman1278
Car: 89 240sx Hatch, the wildcats!
stacy wrote:hey did i figure out which way ur turbo lines go ?? cause I kinda need some help with it too ? you have a pic of ur final outcome?
Its not very hard, all I recommend is to make sure you tighten up the fittings very well before putting the turbo and everything back, also don't forget the teflon. The 90 degree elbow there is probably the most confusing part, so just use the washers and use teflon, than tighten everything, but not over tighten or else you'll strip it, than you should be fine. You really can't mix them up since the fittings are different sizes on the block so like you can't cross the coolant with the fuel and stuff. Just take a pic of your OEM lines to make sure where each one goes to
idahotuner
Car: 2012 Dodge Ram 2500 6.7 Cummins
93 Nissan Sileighty
93 Honda Civic hatch
2011 Polaris Ranger
yea. this helps me some. i need to remebeer how to hook stuff back up for my turbo and figure out where ss lines go exactly.
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
ok iam bumping this question. becasue i went to install my ss lines. and
wont reach the block fomr this side. s oi might have to swap them around. which do you guys run on whihc side. for the coolant lines. i got the oil lines no problembut these are a little confusing.
wzntha
idahotuner
93 Nissan Sileighty
2011 Polaris Ranger
my turbo coolant ine wasnt really long enough. so i have it going straight down. the acuatar rubs on it a little. but that was the only way i could get it to work.
