Quick question about increasing fuel pressure
theother1wstolen
Car: 92 240sx Coupe SE
My car has really seemed to have poor low end power lately but good top end, and i wanna rule out the injectors. what can i safely crank up the pressure to without screwing up the factory injectors?
the converted
Car: '99 BMW M3 6.0
'88 Toyota Celica All-Trac (somewhere in Cali)
'20 Toyota Tacoma
I'm assuming you have a fuel pressure gauge? What are your pressures with the vac line on and off. That's all you need to do to test. If your having low end power issues, check your timing and make sure that the butterfly valves open and close like they are supposed to.
bruinbear714
theother1wstolen wrote:My car has really seemed to have poor low end power lately but good top end, and i wanna rule out the injectors. what can i safely crank up the pressure to without screwing up the factory injectors?
Why would you do that? Cranking up fuel pressure is going to cause you lose more power due to the motor running richer.
