TroubleBound »
https://forums.nicoclub.com/troublebound-u72652.html
Fri Jun 19, 2009 4:45 am
Okay i never thought the day would come when i would own a coupe, or a pignose, but some old man hit my chuki hatch shes now in the garage awaiting her sr. In the meantime i needed a ride to work, and an 89 coupe dropped into my life. (for $1100)
So after i drove it home i noticed that it smelled of gasoline when i got out of the car. Like toucan sam, i followed my nose around the car to where it smelled strongest. Jumped underneath the rear passenger tire/gas tank area to find those rubber fuel lines running underneath my car are old/worn/cracking to the point of fuel seeping through the whole line. I can clearly see that to remove the one side i just take the hose clamp off (after relieving fuel pressure), but the other side runs up above the gas tank, and i need to replace the whole line not just the part i can see. I was wondering where i can find the other end? Is it attached to one of the outlets on the fuel pump? Im thinking it probably is, but if so, then how do i get that end of the hose off. Im sure its just another hose clamp but how will i feed the old hose out and new hose in? Is there a hole on the side of the gas tank somewhere this hose goes through? PLEASE tell me i dont have to remove the gas tank. Heres some pics so you guys know which lines i mean.
I took this one from far away, just to give reference of where these lines where, thats my exhaust and gas tank and wheel there, i took the picture from underneath rear passenger tire.
And this is a little close...hard to fit a camera under there.I was gunna squeeze it to pic the cracks but i squeezed and gas started soaking through
