I did set my timing according to the FSM , warmed it up , shut the car off , unplug the TPS and adjust the idle.I used my timing light to set the timing at 15 degree, 2nd from the right. After shutting down the car and re-plugging the TPS back in, I checked the timing again (with the TPS plugged in this time) and it's set at 10 degree.
I gone through the whole setup again and same result.When I set my timing without unplugging the TPS at 15 degree, shut the car and then after unplug the TPS, I get 18 degree.
Is it normal to have a variation in the timing reading from either a unplug TPS or a plugged TPS.
Is that normal? if not, what could be the problem?
