Quick question about air vents
All things Altima Coupe.
jake7
Car: 2008 Altima Coupe
I was just wondering if anyone elses air/heat blows out at the windshield when its suppose to blow at your feet? When I select to have my heat on my feet it ALSO blows out at my windshield. It didn't do this in my other vehicle so just wondering if this is normal?
THanks
DudeZ
Car: 2009 Nissan 370Z
gone - 2008 Nissan a/c
that isn't normal... it could be an issue with the blower.. have you brought it to the nissan dealership yet??
jake7
Not yet, I was waiting to see what others did before I went in....Guess I'll make an appointment. I have a 3 month warranty since i recently purchased the car so it should be covered.
jake7
I found this in the manual...but when its on the foot position it seems more comes out of the windshield defrost...
HEATER OPERATION
Heating
This mode is used to direct heated air to the foot
outlets. Some air also flows from the defrost
outlets.
1. Press the button to the OFF position
for normal heating.
2. Press the air flow control button.
3. Turn the fan control dial to the desired position.
4. Turn the temperature control dial to the desired
position between the middle and the
hot position.
