Quick question about act ka24de clutch in ca
dvd
will it work? the street/drag stage 1? I searched and i've read about taking out a alignment pin on the flywheel but that was for other brand clutches. So i'm wondering are any of you running a act ka clutch on your ca?
Nismo1182
Car: Z06
all you have to is remove one of the alignment pins on the flywheel. any ka-de clutch will work.
dvd
yep thats what i thought. Thanks man.
F3600
KA24E work too
slo
Car: S13
Are there any pictures online where it shows how to remove that alignment pin out? Is it a simple process to take the pin out or is it something that needs to be on the press to get it out.
anumeric
Car: 1989 RS13, 1986 AE86 GT-S, 1948 2-Wheel Rickshaw.
I took a grinder to mine, worked great.
Wei
mdubc405
Car: white 1989 240sx coupe w/ca18det(t3/t4 .50trim)
you can also use the ka transmission, you just have to swap bellhousings with the ca transmission
Chris859
I was running a ka24 clutch on my ca... Just drill a hole in the pressure plate for the pin to go through, rather than remove it. You will see exactly what everyone is talking about when you try to put the clutch pressure plate on. You will also need to get a dremel or something to enlarge the edge of the bolt holes because they don't quite line up. But other than that it works out fine.
trevr
Car: '07 Mitsubishi Eclipse V6 swapped supercharged
'93 Nissan 240SX Vert CA18det **SOLD**
You can remove any of metal dowels, doesn't matter which. They come out effortlessly, just grab on with pliers and pull. I pulled the one near the red arrow.
The only thing that will give you a problem is using the alignment tool that comes with the KA clutch, it is slightly smaller making the mounting of the transmission a little tougher because it does not exactly center the clutch disc, if you get lucky and you transmission goes all the way in on the first shot your good, if not, move clutch disc around slightly till it is centered to get the transmission on.
One good suggestion before installing the engine and transmission into the engine bay, is to loosen up the transmission fluid fill port and drain port, because your going to have to add it after the swap is done. Be sure to use GL-4 transmission oil.
