Quick question about AAC connector from IACV
gio91
Car: 90 300zx 2+0 N/A
I was looking at the connector on my 300zx and noticed it looked just like a fuel injector connector/pigtail. I wanted to replace it because when I am driving it sometimes disconnects(the connector is dry/brittle). I have a few fuel injector wires left over after I replaced the fuel injectors, and was wondering if I could use those in its place, or do I need to buy a new one. I don't buying a new one if I have to.
Thanks for reading
t.mcginley.jr
Car: 2002 Nissan Altima SE 3.5
1990 Nissan 300ZX NA 2+0
1966 Ford Mustang
I think the pins are the same between the iacv and fuel injector connectors, but the shape is a little different I believe (a few extra bumps). You can get a brand new, new-style one from Z1 for like $10 +shipping that will be weatherproof:
http://www.z1motorsports.com/product_in ... ts_id=5969
ThisIsSparTTa
Car: 91 300ZX TT 2+0
Call Concept Z, they helped me figured it out. Coz knows his s***. Basically, there are 3 connectors on the IACV/AAC, 2 of them are the same, and the other one also happens to be the same one used for the coolant temp sensor up on the coolant bypass pipes. I can't tell you which is which, but CZP can.
http://conceptzperformance.com/Cart/des ... .164.62.64
