gc444 wrote:When I pulled out my airbox to run my temperature sensor I noticed a hose that was attached with a clip. Once I removed it I noticed that the end of the hose was not attached. Did I disconnect the end when I was pulling it out or is it supposed to go nowhere?
Nope... you're okay. As you suspected the loose end of the hose "goes nowhere" ... so to speak.
At first I had trouble placing the hose in your photo because its laying down... (and because your photo was rotated from my point of reference.) For others who may refer to this post I rotated your photo and pasted it next to a reference photo.
As you noticed there is a small clip attached to the hose. This clip mounts in a small hole on the left side of the air box as you face the firewall. (however.... you can just use a wire tie and attach the hose to anything... just place it on the left side of the air box and keep the hose vertical... (like a snorkel)
Here are some photos (as they say... a picture is worth a thousand words)
