Quick qestion about a diff.
SlidinSideWayzSR
Car: 1990 240sx SR. // 1991 240 SR.
i searched really cant find anything on it
anyhow can you use a s13 open diff in a s14
this is all i found when i searched and its for swaping a s14vlsd in to a s13thaks in advance
E7-S14
Car: ess 14 foo!
in this case it works backwardssearch some more
*edit.this forums for info.so i wont be an a**.
most s13s have 5bolt axlesall s14s have 6bolt axles
s14 diff housings have bushings and longer bolts to bolt them up to the bodys13s diff housings have no bushings
s13s rear covers have 4 boltss14 rear covers have 2
s14 and s13 diff housings are identical except for the part where they are bolted up to the body.
sooo
for an s13 diff into an s14 you need to1. Swap rear covers2. Get s13 diff bolts( to boldt up to car)3. Get s14 diff cover nuts( to bolt up to subframe)4. if the s13 diff is 5 bolt, source 5 bolt axels
for s14 diff into s131. swap rear covers2. get s14 diff bolts and bushings( to bolt up to car)3. get s13 rear cover nuts( to bolt up to subframe4. if s13 is 6bolt/ no worrysif s13 is 5bolt then find 6 bolt axels
done and doneyour welcome
SlidinSideWayzSR
thanks e7
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
Just a quick edit. I have never seen a 5 bolt axle S13 R200 diff. But the difference is the diff cover and bushings.
J30 diffs in 94 and the first half of 95 came with 5 bolt axles.
E7-S14
Car: ess 14 foo!
OutToWinPAHC wrote:Just a quick edit. I have never seen a 5 bolt axle S13 R200 diff. But the difference is the diff cover and bushings.
my diff is 5bolt and supposedly came out of a 180sx.but its not a us s13 so i may bewrong.but stilleverything else holds true.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Ahh yeah the VLSD's may be 5 bolt flanged (which you can just hammer out and put 6 bolt flanges into.
marinedrifter240
Car: 95 240
I have a VLSD from a 93 180 and it has 5 hole bolt pattern and im trying to fit it to a 95 240sx so does the 6 bolt flange fit? or do i have to change the axles?
Razi
Car: Moo
You'll need to change axles.
marinedrifter240
Car: 95 240
so will axles from a 180 fit on a 95 240? thanks for the info
E7-S14
Car: ess 14 foo!
marinedrifter240 wrote:so will axles from a 180 fit on a 95 240? thanks for the info
nofind 5 bolt axles or 6bolt output shafts.
you can find 5bolt axles on some s13s or j30s i think.
OutToWinPAHC
Nissan RB20 E46 RHD
1990 Nissan Patrol
Razi wrote:You'll need to change axles.
you can tap out the 6 bolts axles from the stock diff with hammer and do the same with the 5 bolt and swap them
