quick profec b question.
Drty_Jrze
How do you change the reading from PSI to Kpa? Thanks
Atl_SIL40
Car: 89 240sx with 95 sr20 blacktop
ok, first turn the EBC off.. then hold the top left buten and while holding it down tap the bottom left buten twice.. you have to tap the bottom buten within 2 seconds for it to work.... and a side note i had a lot of problems with the warning coming on for no reason in psi mode so i set it up in psi mode and then run it in kpa mode... hope this helps
bim
Car: 93 240sx
Is english your second language?
its button.
Atl_SIL40
geeeesssss a simple thx would have been nice.
240dreams
Car: 240's
there was no need for that. I hope sarcasm was involved. BAN BAN BAN
Drty_Jrze
Thanks.
Dori Dori
Car: Cars of course
bim wrote:Is english your second language?
its button.
Maybe you should have a better grasp on the English language before you start critiquing people.
The "e" in "english" should be capitalized as should the "i" in "its". Also, because you’re using “its” as a replacement for “it is”, it should be written as “it’s”.
240dreams
Car: 240's
good comeback.
