Quick Power Steering Question-91Q
DR.Q
When swapping pumps out, is there any procedure(such as bleeding) necessary for refilling with fluid? Thanks.
Stephen
elwesso
Car: 94 Infiniti Q45t 5 spd
2007 BMW M Coupe
2007 Infiniti G35 S 6MT
Stephen..
There is a procedure in the manual..... Its on the first few pages of the ST section, youll see it (ill email you the FSM section if need be).. Basically it involves something about moving the wheel back and forth.....
Another good thing to do is while the engine is running, unhoook the return line to the res. and let it bleed out that way.. Keep topping it off until you see clear, clean fluid.....
DR.Q
There it is. I was looking a little further back in the pump section. Thanks again Wes. I should be rolling around later today.
Stephen
