Quick POP Charger Install Question
a.p.barron
Car: 1985 300ZX Turbo
1991 300ZX N/A *sold*
So I just finished installing a pop charger on my Z, and then I came across Robo's site on intake positioning.
Here it is if you don't know what I'm talking about:
http://s95014253.onlinehome.us/63104/80397.html
As you can see from his pictures, he advocates lining up the edge of the cone with the edge of the splash guard. Well, when I installed mine, I positioned it in with the cone hanging a little lower than the edge of the splash guard, like this:
Do you guys think I'll run into any issues with it positioned like that? I took my car for a test drive, and it didn't stall or do anything out of the ordinary.
What do you guys think?
DTRUONG9
Car: 1990 300zx tt
some times you might experience stalling or hesitation due to turbulence, but most guy running dual pop have their filters a little low like your diagram. the bigger issue is the filter will get wet easier. you might run into problems at high speeds, but i think you will be fine it not that off. each car is a little different.
