R350Zz33 wrote:what i stated true facts so dont be poking a stick at me
You are shooting blank bullets. Fact, merely.
Fact are always true.
I am going to lead by example how to be constructive with this kind of information.
The truth lies in the tires and the weight on the tires. You used the example of lambo.. assuming that it's a rear engine rear wheel drive. You compared to a hummer 2, let's say for this case a rwd only front engine SUV. Yes. The lambo CAN do better in the snow.
However, lambos usually are equipped with a performance tire and it's width make it more difficult to grip. And as soon as you AWD the hummer, it whips the lambo everytime. Therefore kills your "fact".
So..the correct statement is..
Given the conditions of a rear engine, rwd lambo CAN perform better in the snow than a rwd hummer.
Now.. lets take two 350z... put a lot of weight in one's rear, and the other stock. The one with weight will take off sooner.
The FACT is when you put more weight on the drive wheels it drives better when the roads become slick.
Which also leads the more weight the harder to stop.
