matchstyc wrote:I believe you might be thinking of the sway bar, not the strut bar. I believe the SE & Hicas come stock with a thicker sway bar than other models. These are underneath the car and minimize body roll.
matchstyc you are correct that they come stock with sways. not stbs'...
base = front sway onlySE and LE = front and rear sways, I don’t think there is a difference in thickness between trim models.
and TurboKA37 here are some prices that I found on the NISMO rear stb for the 95-98 s14jspec.com - $270 shipped, (I'm almost positive this is the silver one, you may want to double check with Sam)nismoparts.com - $251.52 (I don’t know if this is the silver one or the black one)courtesyparts.com - $263.41 (this is the black one)
I’m sure there are some other places that have it, but those are the only ones I know of off the top of my head. If you contact any of these vendors they will probably give you some sort of discount if you ask about it.
