I ordered the 14 1/2 x 3 7/8 Black perforated leather. I have done this before on a car about 10 years ago. Here are some tips that I found useful. Put the seams for the leather stitching at 10 and 2 o'clock, as opposed to 9 and 3 because it might be harder to put the seems over the contour bumps on our wheel. Wet the leather slightly at 9 and 3 and pull it to make it wider. I think the key to this install is to stitch it from behind. It will look cleaner and more stock like. Also, I used 2 awls or pointy screwdivers to pull tighter tension after it was sewed on.
