crzycrkr »
https://forums.nicoclub.com/crzycrkr-u37831.html
Mon Apr 03, 2006 9:10 pm
i know, but there is a thin slot in the keyway on the crank about halfway between the front and the gear the oil pump shaft rides on. Once you put the oil thrower on, do you spin it in that little slot so it doesn't go foward or back anymore? Also, which way does it face? Thanks.
