Quick oil question (noobish?)
driven17
Car: 1989 240sx 5spd coupe
I have a ka24e and was told before i bought it, it was rebuilt. It looks clean enough to have been rebuilt and oil is clean when i change it still, like not black or brown, its gold.
I didnt ask if the PO put synthetic in it and i wanted to know what i could do or even if i should/can put synthetic in. Ive heard of the leaks and what not but wasnt sure if there were ways around this, like a "break-in" period of half and half.
So im looking for advice and maybe a trust worthy oil.
thanks
blacksrjdm
Car: 89 240sx, 99 CBR900RR.
Leaks and what not??? Why wouldnt synthetic be ok, no reason in the world why not.
driven17
cause ive heard either 1) older seals can leak or 2) if he used non-synthetic before it would build up to stop any leaks and when switching to synthetic it will like clean it up and leaks would starts where the buildup was
blacksrjdm
#1. But you said the engine was rebuilt... Therefore, new seals.#2. Changing your engine oil wouldnt break any deposits up.#3. An engine flush wouldnt be recomended because that WOULD break loose deposits and could cause it to leak.
Put the synthetic in, or regular oil. Not gonna make a difference in the world. And yes you can switch back and forth from syn. to non syn. and it wont hurt anything. No matter what anyone says, doesnt matter. Hell, if you wanted you could put 2 quarts of syn and 2 quarts of non syn. and it wouldnt hurt it. You can mix, change, etc... wont make a difference.
X abisai X
Car: 91 240sx coupe
blacksrjdm wrote: Hell, if you wanted you could put 2 quarts of syn and 2 quarts of non syn. and it wouldnt hurt it. You can mix, change, etc... wont make a difference.
I've never heard of mixing synthetic with non synthetic, i always heard that you would have to flush the engine out before switching from one to the other
mattblancarte
Car: 2005 BMW M3 Comp. Coupe
If the motor is broken in, and you're only seeing street use from the car, you can just use cheap oil. It's a good thing if you're seeing clean oil at regular change intervals. This means that it hasn't broken down much, and that you've got a tight motor.
If you don't mind spending 30-40 bucks per oil change, run a K&N filter and Mobil 1 synthetic.
numbnuts240
1974 Datsun Fairlady-Z 250GT
2011 Ford Focus
2010 Mazda 3
hbpignosePA
Car: 90 240sx hatch (Jackstand Queen)
78 Datsun 280Z (RIP)
89 Toyota Cressida (Sold)
86 Nissan 200SX hatch (sold)
83 Nissan 280ZX turbo (parts car)
90 Volvo 240 (sold)
80 Toyota Cressida MX32 (new daily)
^^ hope thats just for winter, thats hella thin
wat about mixing weights?
like 15-50 and 10-30
i got a car that burns oil
and it has 10-30 in it now
but got some 15-50 layin around
(for my beater not the 240)
blacksrjdm
Also a misconception...there is no reason why you cant mix them, or just switch from one to the other and then back again. Will never hurt your engine. U can contest it all you like, but u can still do it. Thats like cars that say only to use mobil 1. Thats just because mobil made a deal with that car company, and they have to put that on the cap.
Now, I wouldnt suggest mixing the oils or switching back and forth, what I am saying is that if you are short on money at one oil change, dont be afraid to change it with non synthetic, just make sure to change it before its due again. Synthetic oil will allow you to stretch the oil change interval slightly, although, wouldnt recommend that either. Also, you can add a quart of non synthetic to an engine that has synthetic in it, if thats all you can find. Will not hurt anything. Although, if your low, its probably time to change the oil anyway.
blacksrjdm
hbpignosePA wrote:^^ hope thats just for winter, thats hella thin
Just use 10w40, little thicker.
blacksrjdm
numbnuts240 wrote:
Perfect example of syn and non synthetic mixed...
Shabbernigdo
i got my car with 150K miles on it and switched to synthetic with no problems.
X abisai X
Car: 91 240sx coupe
good to know if i ever want to switch to synthetic for whatever reason
