Quick offset question, need to know if these fit HELP PLEASE
URM S14
Car: 95 240sx
Hey guys, rota wheels just came out with the advan rgII take-off called the rota boost. they have only in 17x8 in 32 offset. will these fit an s13 front fender or does it need modification? im sure itll fit the rear but im concerned on the front as i dont want any rubbing. i really dont want teh fenders rolled. the car currently has KTS coilovers which i hear has good clearance inside.
Anyone have this offset? do you guys have a graph of ranges that fit?thanks!-Chris
240sxjeff
Car: nissan 240sx zenki version
yeah they should fit because I had 16x8 32 offset on all four. If anything you can run a 5mm spacer which is what I did but only because I wanted the rim to poke out a little more not because of clearance
URM S14
Car: 95 240sx
thank you sir!
nismofly
Car: 89 Nissan 240SX Hatch
run a 215/45/17 tire and youll be fine
lots of people run 17 x 8 + 35
Juujai
you'll be about an inch sunken in but if you don't mind that's fine it'll fit. it should clear stock shocks also.
URM S14
Car: 95 240sx
you guys think a 225/45/17 will fit ok?
nismofly
i think your pushing it with that, Smith had 17x8 +35 with coilovers and i think he said he had to run 215/45/17 so it would clear
