Quick Noobie Question
GEO
Car: 95 240sx KA-T
Ok I want to get AGX STRUTS and SPORTLINE springs for my 95... What kind fo SIDE effects will partake? WOuld camber be a REAR issue? Or what? I don;t need to eb replacing my tires ever 12 weeks.. haha.. anyway, elt me know.
Structure240sx
you will have negative camber in the rear, maybe the front too. your tires will still last a while but the inside will be worn much more than the outside of the tire. this can be fixed with ruca's. i have the ebay specials that are like $150 and have been holding up great for months now.
GEO
Car: 95 240sx KA-T
SO basically , rotate my tires huh, when they start to show wear..
Meantime
Rotate them pretty frequently if you are running neg. camber in the back, you're probably going to have a decent amount with Sportlines. As long as you keep up on it the wear won't be too bad.
I have a bit of excess camber with the RS*R's but it's just slightly over factory spec.
BTW what's with the avatars mang? I liked the other chik better.
Structure240sx
yea you can rotate them if you dont want to fix the camber problem. remember though if you go with a performance tire it may be directonal. in that case you could only rotate it on the same side of the car. if you go with wider wheels/tires in the rear then you wont be able to rotate a directional tire
deezlins
Car: 95 240SX SE
remember to get an alignment too :)
GEO
Car: 95 240sx KA-T
Alright thanks. I am going to need a camber kit and that tension rod in the back like structure told me before.
Structure240sx
its an adjustable ruca- rear upper control arm, tension rods are different
candela
Rucas are very easy and cheap and its a very good idea. I also have the ebay specials on my S14 and they hold up. I run a staggered settup and have some expensive tires so its best IMO to run someone sane camber angles :) Still at about -1* is fine for me, i still get great turn in and dont oversteer to much anymore (which is prolly do to the tires anyway).
silvia tunner
Car: 1995 Ruby Pearl s14
i have the sportlines on my 95 but my stock shocks are blown. the sportlines have a good drop and not to bouncy
http://www.cardomain.com/id/projectmaroons14
240SicknessX
Car: 96 240 SE
I have a 96 s14 and i have the kyb agx +sportline combo.
after my alignment the fronts had no positive or negitive camber. the rears could only adjust to get me 1.0 neg camber. If i wasnt sliding all over the place my all season tires 205/55/16 might last 4 months in the rear with 1.0 neg camber. Im ordering the alignment kit as we speak to correct the rear camber issue.
Structure240sx
true, i notice tons more traction after installing the ruca's and setting them by eye. i still have to get an alignment tho
