quick LSD question
SrS13
Car: 1990 Fastback, 1993 Convertible Coupe
I'm going to get a Stock 180sx 1 way LSD. I will be swapping it into my 1990 240sx. My question is: Will I need the 180sx LSD axles? or will the stock 240sx Differential axles work on the 180sx LSD?
thanks
GTS4-R
Car: my feet
it should come with the whole entire pumpkin so u would be all set....otherwise ur assed out
SrS13
Yeah Im getting the entire pumpkin but will I need the axles off the 180sx as well?
dj_lennon_franz
Car: 1992 240sx
for the S13 LSDs i dont think u need the axles...you just need the output shafts i think...im pretty sure the 180sx LSD has the 3 star bolt pattern that the open diff has...and the 180sx LSD will work in the open diff pumpkin...again u just need the output shafts
