nousablenames133 »
https://forums.nicoclub.com/nousablenames133-u46182.html
Mon Nov 27, 2006 7:22 pm
Torsen/Helical differentials act like open differentials until there is a difference in torque allocation. They prevent excessive torque allocation to a low traction wheel, peg leg drive, by using worm gears to limit the amount of torque alotted to one wheel based on the traction of the other wheel.
VLSDs act like open differentials until there is sufficient torque allocation difference. Locking pressure is created when the torque difference in the axles creates enough friction to expand the silicone in the diffential oil, pushing the pressure plates together
Clutch type LSDs act as a spooled or welded differential until there is sufficient torque to "break away" the pressure plates.
