extheflow »
https://forums.nicoclub.com/extheflow-u3097.html
Sat Apr 03, 2004 8:00 pm
bust out the ole' FSM and find the fuel pump RELAY,not the actual power wire.you'll also find that the relay is actually in a convenient location so you should conider relocating it. you want your switch on the ground side of the relay for convenience. disconnect the ground side of relay coil.run a new wire to your witch then from the other side of switch just ground a wire to chassis.this does nothing though if someone knows where your relay is...they can just jump the relay socket.
