quick J30 check question
silk240
Car: '92 white 240sx coupe w/ blacktop sr20det
to check to make sure it is a vlsd J30 diff, if you turn one side the other side should go in the same direction, when not holding the part where the driveshaft bolts up to, correct.
98s14inaz
Car: 2010 Nissan Titan Quad Cab
silk240 wrote:to check to make sure it is a vlsd J30 diff, if you turn one side the other side should go in the same direction, when not holding the part where the driveshaft bolts up to, correct.
yes.
silk240
thanks
