quick help about offset ... 18x10 J+0 and 18x12 +13
billy hoang
Car: 2003 Subaru WRX
hey wassup fellas , i'm really close to about purchasing a set of wheels for my 1995 s14 . i saw a set of wheels that I like and I've tried using the offset calculator and using the millimeter conversion tables and did searches to see if anyone else is running a similar offset but didnt get a solid answer ....
can you guys help me out and tell me how would these wheels fit on my S14 ?
Work VS-XX18x10 J+0 and 18x12 +13
if it matters , i'm running stock brakes and Cusco ZERO-2R coilovers and have Cusco RUCAS and other Cusco components on the car .
thanks
AmoebAssassin
Car: 1991 Base fastback 5spd, black
They will fit awesome, but you have to do a severe pull, maybe even overfenders.
Fitting wheels like that is NOT for the faint of heart.
billy hoang
oh sorry , i forgot to add that i will be intending to get 30mm front fenders and 50mm rear over fenders and was hoping that this combo would let the wheels work .
would it hit the coilovers ?
nismofly
Car: 89 Nissan 240SX Hatch
those will fit fine with 20mm fronts
however in the rear you should run 30mm instead of 50mm
