quick headlight question
burgerwitfry
yea im wondering whats wrong with my headlights for an s13 pop-up because one headlight is brighter than my other and its not the bulb, so im wondering what can it be? any info would be helpful thanks
Thebigjc
Car: 1990 240sx/sr20det
I'm just guessing, you probably have a bad ground or a short somewhere on the wiring for that headlamp.
burgerwitfry
how do i fix this bad ground wire/ short wire and how do i locate where the wire is short?
Thebigjc
Search the forums for those answers, do a search on headlights you should come across soemthing. Also somone i here has a link to the FSM which i would assume has the wiring diag. Your gonna need a multi-meter though.
Also check to make the the light connector isn't just Fowled or corroded.
vancouverbc
Car: 1991 240sx
Check to see if any of your others light are out.
nuts510
Car: sr20det 95 240sx, rb20det 93 240sx convertible, 78 280z turbo, 71 ca18det datsun 510, 72 scout,88 CR
check the wires that go to the headlight especially the last foot behind the headlight where the wires are flax has a headlight goes up and down. I've had more than one with that problem and it would be the wires are almost broke. Also is it dimmer on both the high and low or just one ?
burgerwitfry
the high and low beam, thanks for the help ill probably check it by today, any suggestion if i come up with a broken wire or corroded connectors?
