Quick fmic question
capowered240
Car: 90 240sx
Looking for a fmic. Will this fmic work, or is it to small?
http://cgi.ebay.com/ebaymotors...QrdZ1
damesta
Theres no such thing as too small, its bigger than stock and if you really wanted too, you could run without an intercooler. Ofcourse, larger would give you better cooling efficiency, but that one would work fine.
capowered240
Car: 90 240sx
Alright I'll probably get that one then.
capwred
that should work fine.like damesta said its bigger then the smic and its should get more air flow in the front of the car.
float_6969
That's plenty big enough. It should support 250-275hp pretty easily. Maybe more.
capowered240
Car: 90 240sx
Alright, I just got done ordering it. Now its getting the piping done. I guess I can go to a muffler shop and get it done. here is a pic of wha I've done so far.http://putfile.com/pic.php?pic...&s=f5
Modified by capowered240 at 11:03 AM 6/10/2006
Modified by capowered240 at 11:27 AM 6/10/2006
1via
Does anyone have the xs power fmic? If so did it fit without having to do something to the pipes?
capwred
i got the xs power fmic and yes you have to mod the cold pipe.i just got someone to make me a cold pipe.but if you can fine a cold pipe for the greddy manifold for the sr20 then i believe you can use it.
DrIft Ready
Car: 1990 silvia built sr..
works great on my homies 24 did it cheap top mount with vented hoodquick boots and cools way better than stock sidemount
91RMKS13
Car: 1992 240sx
I like that setup ^ but a little bigger intercooler and a v mount setup and not only would it be better but it would be JDM TYTE YO!!! But I really do like that, I bet it helps with spool time. Plus it looks really simple, bet it would make finding a boost leak a lot easier.
