quick emissions question
fender-startocaster
Car: 1990 240sx
whats up guys? i have a quick emissions question. My car failed smog the other day. The people where being doushes and they didnt want to tell me the reason for the failure. sooo heres a pic of my results. Any idea what would cause these really high numbers? for example cat, egr, bpt valve, oxygen sensor. Any help will be greatly apreciated.
zach-Ka
Car: 1990 240sx (SR)
fender-startocaster
Car: 1990 240sx
wow! that is great information. Thank very much!
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
i would say to check your air filter and pcv, but your running what some call "pig rich"idle mixture. plugs,CTS,some quick things to check. what does it say your timing is at?egr /bpt wouldn't couse that. cat is a possibility, but you want to check the little stuff first
r3v_v3ng3
Car: 91 fastback ka-t
read up on high hc's and co's. its very rich. the reason they won't tell you whats wrong is because your gonna go home and replace those things they say and your gonna return and it may fail and blame them for it. if its a test only station they get in trouble for telling you what may be wrong. besides they need to make money
Wc240
97 Nissan 200SX
06 Scion xB
zach-Ka wrote:http://www.nichols.nu/tip517.htmI hope this helps.
theres a suprising amount of mis-information in there. mabe 1 or 2 lines of true/useful info
zach-Ka
Really! Well sorry about that guys. I don't know about emissions tests I live in TN. I just found that when I searched and it seamed as though it would held. My bad fellas.
fender-startocaster
Car: 1990 240sx
zach-Ka wrote:Really! Well sorry about that guys. I don't know about emissions tests I live in TN. I just found that when I searched and it seamed as though it would held. My bad fellas.
Its cool man. Its the thought that counts hehe
anyway turns out i had all my vacuum lines mix up while some where unpluged. Hopefully this is the problem thought i think its not.
I know its bad but the $150 illegal smog doesnt sound to bad right now.
Wc240
97 Nissan 200SX
06 Scion xB
for next time, try to find a test only place that offers a free retest. vac lines are pretty easy if your good with a diagram. 150 smog might not be worth it becouse it sounds like itll cost you alot less in repairs
dont be sorry for the bad link, not your foult. atleast you tried to help, unlike 80% of all the other a-holes on these forums
owlznite
Car: '89 240sx Redtop sr20det swapped Fastback. Black, power window/door, FMI, Koyo Radiator, ACT 6-blade
You know when i had problems like that back in the day you know what worked for me?! get that guarantee pass smog s*** thingy. you can get it at any auto-parts dealers. fill up your tank of gas and add that s***. drive it until your tank is almost empty. take it back and your gtg!
-tony y. cali
