John Dixon »
https://forums.nicoclub.com/john-dixon-u22208.html
Sat Jun 06, 2009 11:19 am
The injectors are Bosch 440cc top feeds (type 3 multi jet).
Yes, it's crank HP, I never quote wheel HP, it's meaningless. Changing tyre pressures, running in different gears, strapping the car down harder can all change the wheel HP figure significantly but if you do coast down properly you'll always get the same crank hp figure.
Cheers for the pics on the intakes. I'm actually going for something similar to either the LT5 pic or the VG30DETT setup depending on what intake lengths turn out to work best. I'll change it all when the new 52mm throttles go on. I'm hoping most of the restriction turns out to be in the 2.5" ducting feeding the box as there is a resonable x-section area inside the box its self.
