quick diff question
sipallday
hey guys im currently changing my differential, does anyone know if i have to remove the axels completly remove the hub and everything? im doing this alone any help would be appretiated thanks
sipallday
someone please
ILoveMyRHS13
Car: 1990 Nissan 240sx (Hatch)
Are you changing the axles too? You only need to pull the diff itself out. It should be the 12 12mm bolts that connect the output shafts to the axles, 4 14mm bolts that connect the diff to the driveshaft, the 4 17mm acorn nuts holding the cover into the subframe, then the 2 17mm bolts in the snout. You'll have to wrestle the diff out of the output shafts, it's not an easy job for one person.
sipallday
thanks my man im almost finished with it what i didnt know is that i can just move the axles without having to take the brakes and everything... did it all solo thanks alot bro :)
adrianfromthecastle
Car: 1992 Nissan 240sx
good boy
