its probably one of your fog light bulbs since yours has the jdm ones. unlike the american ones. easiest way to check your lights is too have the car off and just turn all your lights on and check them and for the brake lights you can have someone hold the brake for you.
Postby
yodawill2000 »
https://forums.nicoclub.com/yodawill2000-u27169.htmlFri Apr 09, 2010 10:42 am
Mine lit up when I had a weak brake light.Wasn't the whole way burnt out.I believe too much or too little current draw will trigger the red warning light.
Postby
Defiant »
https://forums.nicoclub.com/defiant-u43224.htmlFri May 07, 2010 7:44 am
The easy way to check your car's lights is to drive into a strip mall parking lot and check your reflection in the store windows. Trouble with having an assistant "help" is the old "Yes it is.... no it isn't.... yes it is" when asking about the turn signals.
